which gearing you guys drive with which Motor and how much S on the lipos?
now i am driving the MMM2200 combo with 5s hyperion and 13 pinion
the pinion is to small and the 5s lipo is too much for the mmm 2200 motor
i go next week with 4s lipo and 15 or 16 pinion i think
diff oils in the middel and front under 15 000 makes the car to unstable. its no mather if nitro or if brsuhless. here in germany and europe much pro drivers drives heavier oils. 20 - 50 k in the front and middel
5s on the 2200kv motor is extreme for sure. I use a 1700Kv or 1550kv motor on 5s.
I assume your tracks have super high bite/traction and a smooth surface - lower traction and rough surfaces generally require lighter diff oils for better stability - I wouldn't run heavier than 10k in the front and 20k in the center even on a smooth clay track.
i am building my second mbx6t brsuhless truggy. so i will tkae rc monster parts again i like the balance and the leightwight compare to the tekno kit
so my quation
woul the rc monster battery tray from the mbx6 buggy fit to the mbx6t truggy? i do neo need a big batterie tray, 140mm are more then enough for my lipos.
