FastXR
10.20.2009, 06:36 PM
Its not Friday yet. :)
I can pretend its Friday and set the date on my computer to Friday.
DarkRedemptor
10.21.2009, 01:30 AM
3.5KG = 7.8lbs, so I think the MMpro would do fine with the T8 motor- even being delta wound its still only 2050kv, pushing a pretty light vehicle. I would look in the MMPro beta testers thread and look at the feedback for more ideas.
Originally Posted by Thomas Porfert View Post
As long as you gear conservatively, I don't see a major problem with this. Being that it is a Delta wind, make sure you are running lowest timing (0°). That motor is very close to our 2650Kv motor, so it should be a good fit on a 3 or 4s LiPo setup. I wouldn't be too surprised to see the fan kick on from time to time. Let us know how that works out!
Thomas Porfert
Castle Tech Support
Thanks for your answer, I will try the MMP
10.21.2009, 09:45 AM
Personally, the biggest advantage with the MMPro is the 6s capability. I like having a "1s" voltage headroom (for more leeway with braking spikes), so I would run 5s on a lower kv motor. Still gear conservatively and set the MMPro options to be gentle.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
10.21.2009, 09:57 AM
I agree with BrianG - a good quality 5s pack should allow the MMP to efficiently and safely provide good power. Time will tell how well it handles 1/8 buggies in the real world, but I tend to believe it should handle 'reasonably sane' 1/8 buggy duty rather well(no doubt there are people that will quickly find a way to kill it). :)
10.21.2009, 10:05 AM
There ya go! If the monster says it is so, then it is so!
People do run the regular MM in buggies (and the MMPro is pretty similar to the MM in current-handling), so 4s should work fine, but it will get warm. 5s on low kv is the way to go.
Or, if you want to use mechanical brakes, run the full 6s and an even lower kv motor (~1300-1500). If you want to retain motor brakes and run 6s, I would solder on an extra TVS/capacitor module to the power wires.
Ferret
10.21.2009, 12:59 PM
Brien,
what values would you recommend for the TVS and capacitor?
Thanks,
Avner.
10.21.2009, 01:06 PM
For 6s usage, 35v low-ESR caps (you can tell by the 105*C rating). Actual capacitance varies. If I'm gonna add caps, I like to at least double what is currently on there. IIRC, the MMPro has 3x220uF caps (660uF total), so anything around that would work. You could get one cap or 2-3 smaller ones - doesn't matter (although I personally prefer mutiple smaller ones for better heat dissipation and transient response).
The TVS should be similar/same to what Castle puts on the MMM. Can't remember off the top of my head the exact part number though.
Or, you could get something like this: http://www.shopatron.com/products/pr...ber=5685/135.0
snellemin
2 KiloWatt RACER
snellemin's Avatar
10.21.2009, 01:32 PM
And if you decide to run low turn motors buy two or three of the Novak ones, if you can't build your own.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
Thomas
Thomas's Avatar
10.22.2009, 06:19 PM
... If you want to retain motor brakes and run 6s, I would solder on an extra TVS/capacitor module to the power wires.
Just because it has a fan, doesn't necessarily mean it can't handle 6s and electrical brakes ;)
Or was that a problem with the beta units?
10.22.2009, 06:30 PM
Has nothing to do with it having a fan or not.
10.22.2009, 09:11 PM
5s is the new 6s, its a fashion thing, all the cool guys are going this route ...
FastXR
10.24.2009, 08:34 AM
Well guys the MMPs are up and available for purchase in the RC-Monster store, I just ordered mine, can't wait to try it.
nitrostarter
nitrostarter's Avatar
10.24.2009, 02:56 PM
I can't wait to try mine too!
N. Rustler conversion
Cain
10.27.2009, 10:05 AM
Ok. I have heard of people getting these in already. So, does anyone have any info on the following usage of the MMPro:
- 4S 1/8 Buggy
- 1900Kv - 2200Kv motor (sensored info preferred but sensorless good too)
10.27.2009, 10:29 AM
Hmm, I always thought 5s was the new 4s.
I much prefer 5s to 4s lipo, the amp draw is considerably less, and everything just seems to run alot cooler. Plus you can get away with lower spec batteries if you desire, or just not push good batts as hard (they last longer that way).
