squeeforever
squeeforever's Avatar
03.08.2010, 06:28 PM
Originally Posted by Finnster View Post
lol get really good and maybe you can help refurb some of the MMM that are backlogged at CC ;)
BTW, do you have a recc for a replacement drive? A coworker of mine said his drive won't read anymore and was contemplating buying a broken one off ebay to get a new drive. Are there better ways to do this? He has a hitachi drive (so he says.)
Thanks
To do that, he would have to have the firmware of the drive flashed since the drive is married to the board with a serial code.
Originally Posted by Modding_out View Post
Help me out here guys......The way I under stand it is this machine t-maxxracer32 bought disassembles broken computer chips to their core parts then re-assembles them? what about replacing broken layers on them, not just the solder.
Then your SOL.
t-maxxracer32
t-maxxracer32's Avatar
03.08.2010, 06:44 PM
Send me an e-mail: brasuca2478@hotmail.com
email sent
Thanks
Im not sure what your asking here. what is a recc? or what does it stand for? i tried googling it but came up short.
fixing DVD drives is something that I am working on right now.. whether the drive is not reading the disk, showing the "open tray" error or just not opening... These drives are somewhat a mystery to me as there is not a whole lot of info on how to actually fix them. Stupid tricks that people come up with but they really are doing nothing to fix the problem.. just for some reason the drive decides to start working again.
If the drive just does not read anymore I would guess the laser is broken or some component inside the drive is failing.
I suggest he just get a drive off a broken xbox (hopefully the drive is not broken..)
again.. once i figure out these problems ill post it up
basically this machine lifts up certain chips off boards that cannot be done so with a regular solder gun. The chips I guess you could say are heat treated on the board.. meaning it is placed in a specific spot then heat is applied that melts the solder causing the chip to join up with the board.
Ill get a video of it in action once I figure it all myself.
The work that actually fixes the xbox (reballing) is done by hand and that is going to be the hardest part i believe. Lifting up the chip will be all of a matter of pressing a button... once i calibrate it and everything.. putting the chip back in place after the reballing will take about 30 seconds of precision placement then all I will need to do is press a button to get it melted back on.
this is all theory. Tomorrow when the machine comes the true test comes.
and as squee said.. you SOL if you need certain layers fixed inside a chip. I do not encode or write the chips.. I just fix the bad solder jobs.
lutach
lutach's Avatar
03.08.2010, 07:01 PM
Originally Posted by t-maxxracer32 View Post
email sent
Replied. Don't get upset for the straight forward answer. It's the same answer I give to all the places that sends me e-mail regarding reballing. One other suggestion, get a few scrap chips and train your butt off. Check ebay and local places that recycle electronic products.
rawfuls
roofles.
rawfuls's Avatar
03.08.2010, 07:16 PM
3. In the futur if the business is doing well I will spend the extra money on a domain name, but the website is not for me to gain actual business... it is more so just for testimonials and a place to put all my work. Ebay, youtube, craigs list, and word of mouth will be my biggest business
In no means should I be criticizing you, as I am quite cheap also ...
After listening to almost a hundred computer podcasts, sounds like GoDaddy is only about $10 bucks a year?
Quite cheap if you ask me, but me, I always change my mind so paying $10 a website I'm gonna end up ditching a few days later isn't the thing for me.
Really looking forward to your success-fullness of your business!
t-maxxracer32
03.08.2010, 08:29 PM
hm. I figured having your own domain name would be 25-30 a month..
Once i get better at HTML formatting and all that jazz I may make a sweet site that I pay for.
skellyo
skellyo's Avatar
03.08.2010, 10:25 PM
You can have a site hosted by godaddy for $4.99/mo. Check out their hosting plans on their site. I have been using them for my personal site for several years now and have been extremely happy.
t-maxxracer32
03.08.2010, 11:51 PM
what makes it so much better than webs.com other than a more professional look?
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.09.2010, 12:53 PM
The equipment looks pretty sweet. I think that's your ace in the hole for getting business. Definitely show pics of your equipment at work with any ads. Start a Facebook page too... I think that would be huge to help the biz.
http://www.inmotionhosting.com/
That's another bargain for web hosting esp if you need more bandwidth. I know a couple guys using them. But for a simple site without a ton of pics or video etc, then about any $5 host will work, like go daddy. Go daddy does a good job making things simple and easy to purchase and manage all in one spot.
btw, I have an original XBOX that started giving me "damaged or dirty disk" errors, and has progressively gotten so bad that it's pretty much impossible to use. Used to be, that it would get an error a couple times, but eventually would read the disk... and it would play fine after that, until you restarted or changed games. Now I just gave up because I tried restarting over and over and it won't work. Even a brand new game won't work.
I thought maybe there's dust inside the DVD messing up the laser or something. But it's next to impossible to tear into it that far. Tried blowing air inside the drive but that didn't work. Any ideas? Replacement drives cost more than a used XBOX
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
t-maxxracer32
03.09.2010, 12:56 PM
thanks for the info on the site
Ive never messed with the original xbox, but I do have one sitting at my house broken. Not sure if the drive is working or not, but PM me if you want to try it out
t-maxxracer32
03.10.2010, 01:51 AM
Got the machine in today and I am quite pleased
other than a cracked software disk everything came in perfect condition and I got it all up and running with little problems
Here is a few pics of it all
My work station
The Jovy 7500 reflow station!
chip after I pulled it off and cleaned it
chip I pulled off and have yet to clean
the board after I pulled the chips off. It has not been cleaned yet
rawfuls
roofles.
rawfuls's Avatar
03.10.2010, 01:59 AM
Damn! Look at all those shotty solder joints..
Now I know what you mean.
t-maxxracer32
03.10.2010, 02:21 AM
well,
it only looks that bad because when I pulled the chip off, the solder followed it causing the mountain of solder.
the chip on the left I played with a bit with my soldering iron so that is not exactly how it looked once I pulled the chip off, but the area on the right has not been tampered with since the chip was pulled off
rawfuls
roofles.
rawfuls's Avatar
03.10.2010, 02:23 AM
Still, very dusty.
I would never leave my computer components that dusty.
I do a weekly, or sometimes monthly cleaning of all my computer, and computer areas.
Maybe that's why they last a long time :P
Or not..
t-maxxracer32
03.10.2010, 02:28 AM
Oh,
This is because this is an old school xbox and I could care less how clean it is because it is just a scrap board that I will be practicing on.
All the 360's I service get a thorough cleaning
lutach
lutach's Avatar
03.10.2010, 09:41 AM
Nice.
