Something, anything, nothing
05.15.2008, 07:28 PM
I got everything soldered up now and I really like those 6.5mm bullets. They are beefy but were a breeze to install. Now just waiting for batteries to charge. I am only doing a test run right now as my 3s lipo packs are not in though.
05.15.2008, 07:29 PM
Originally Posted by lincpimp
Got mine today from Mike. Installed it in MM's old revo with the slipperential. Running a hacker 7xl b50 on 4s (2 trakpower). Ran it for 15min and it worked fine. This is a high draw setup, but the esc stayed cool. I used the internal bec and it worked fine for me, so I guess that I got a good one! Mine came with connectors in a little baggy, so I used them. Nice connectors, I will have to buy some more, what size are they, 6.5mm?
That is an awesome setup! When I had that Revo I ran a Feigao 7XL through a MM on 5s2p A123, with a 20t pinion. Top speed was ~45mph, and the 7XL (finned can) didn't go over 160deg. F. The MM on the other hand would thermal in a couple minutes without a fan. If only the MMM had been in production while I still had that truck...
And yes, 6.5mm plugs.
05.15.2008, 08:26 PM
It seems powerful, but the hacker is getting near 160f! I think the center diff has been leaking, so I may be over revving the motor, not much load with the front tires off the ground. I currently have the punch control at 100% and the timing at normal.
05.15.2008, 08:42 PM
Well, my bec just bit the dust, so I am out in the first few minutes.
Oh well, it happens. I will just call CC in the morning.
It was smooth as butter while it ran though. Align 600XL motor. Did some nice low speed passes, and it crawled around with no hesitation. All in all not bad for a 6 pole sensorless outrunner.
05.16.2008, 06:50 AM
Unlucky, so how many have died now?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
05.16.2008, 04:57 PM
mine met its maker today. Best 12 minutes of my life that ended in dissapointment (next to that 1 time in Thailand)  The guy at castle was all "sorry we had some bad components go out in the controllers, send it back we are moving the monsters to the front of the line to be fixed"... I said dude dont worry about it, it was totally worth it !! 1515/1y on 6s was all id hoped it would be, even if for that brief moment lol
05.16.2008, 05:03 PM
Mine just died in my E-Maxx. Same symptoms as everyone else! Back to Castle it goes!
05.16.2008, 05:57 PM
Must be around 15 died now or more?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
I like chocolate milk
05.17.2008, 12:31 AM
Kinda wondering how you got from 6 to 15, but ok.
05.17.2008, 01:55 AM
Quite a few have died in the last 24 hours as most people have now recieved their MMM and have it all hooked up. There are still probably hundreds out there that still haven't recevied theirs or mounted there. Not everyone that owns a MMM is on this forum
Check out this MMM
There also seems like alot of fans are breaking
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
05.17.2008, 04:05 AM
Check out this MMM
bit of a shame, for those outside the states. with my luck it will break.
the fans will always be a soft spot, has anyone run theirs without the fan? does it need it on say, 4s?
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
I have no idea what's going on
05.17.2008, 07:18 AM
Ouch...that looks pretty painful! Looks like perhaps a short occurred somewhere there, around the status LEDs (maybe a separate issue?). I just received my MMM today, but don't have anything to run it in just yet...so I hope it's a good one.
As for the fans...well, anyone who jumps their truck (be it on a track, or bashing) is going to be delivering quite a bit of punishment to that little computer fan. Still, it's gotta be a pain for it to keep breaking.
05.17.2008, 11:44 AM
Drift Buddy --
Your pictures you posted of a failure is atypical. That's a main FET failure. Did the fan die on that unit prior to the failure?
Patrick
Patrick del Castillo
President, Principle Engineer
05.17.2008, 11:47 AM
Patrick, I sent my dead one in Attention Repairs/Chris, that's what I was told to do. It will be to CC Tuesday via fedex. What kind of turn around time do you expect?
I am just trying to make plans for next weekend and want to know if it will involve the Monster or not.
Thanks.
05.17.2008, 06:59 PM
Originally Posted by Pdelcast
Drift Buddy --
Patrick
thats what my mm looks like that i just sent to you guys for replacment.(along with a check) mine desoldered one of the power wires. and melted the case. Made for a good show though
