Lizard
Lizard's Avatar
08.08.2015, 09:55 AM
Just tried the HPI Vorza ESC tray for the old Mamba Monster: It also works with the X. Hole spacing for the switch is different, but that's no big problem I guess ...
08.11.2015, 12:27 AM
Impressive 2min cycle testing time is quite a lot. What's the actual test failure rate dare I ask?
Lizard
Lizard's Avatar
08.13.2015, 06:41 AM
Torque Control Adjustment
The controller's torque limit is controlled by the AUX wire signal. The torque control is scaled from 0.1 at 1.1ms signal received on the AUX wire to 5.0 at 1.9ms. Torque control is disabled when the input exceeds 1.9ms. If the AUX wire becomes disconnected, the controller will use the torque limit set in Castle Link.
Could you make this adjustable, Patrick? I have a Traxxas TQi radio that doesn't have any endpoint or trim settings for the third channel. It only has fixed 1.040ms, 1.500ms and 1.960ms. So if I understand the above correctly, for the 1.040ms signal I get Torque Control 0.1? Or disabled? It's below 1.1ms. For 1.500ms I get something between 0.1 and 5.0 and for 1.960ms (above 1.9ms) I get Torque Control disabled.
Perfect would be IMHO, if one could define a table with Torque control value and associated ms value (But I guess that would be quite some work).
But maybe it's possible to make just the endpoints adjustable in the ESC? If it could be set to a range between let's say 0.5ms and 2.5ms, the three possible ms values of the TQi's third channel would correspond to three usable Torque control settings (I realize 0.5ms and 2.5ms is outside of normal signal range, it's just to be able to adjust the range of usable Torque control values).
crazyjr
crazyjr's Avatar
08.23.2015, 02:14 PM
You could replace the 3rd channel switch, with a potentionmer, similar to the ones used for trims on channels 1 and 2 on older radio's. Just need to drill a hole where it won't cross out anything else.
Dragonfueled
Nore more bump boxes and after run oil
08.13.2015, 07:21 AM
I would just love to know what the actual torque control is. Like a way to know what your setting is on when using the third channel.
Brushless ..... I put that s... In everything.
Lizard
Lizard's Avatar
08.13.2015, 08:22 AM
Yeah, that would be nice. Like the castle link software already shows the ms-values of the throttle calibration maybe it would be possible to make the ESC also save the last-seen ms-value of the extra channel so that it can be displayed in the castle link software.
Dragonfueled
08.13.2015, 09:05 AM
That would be cool it's nice to know where it was just for fine tuning and getting back to the setting you liked
Lizard
Lizard's Avatar
08.13.2015, 12:22 PM
Just an idea: Would it be possible to use a servotester with a small display that shows the ms-value, permanently attach it to the aux wire (and positive/negative of course) and leave it on the car? That would do exactly what we want, or? Just not remote-controlled, but that's okay for me ...
Pdelcast
Pdelcast's Avatar
08.14.2015, 02:25 PM
Yes, that would work... But really kind of defeats the purpose of the aux wire.
Patrick del Castillo
President, Principle Engineer
Lizard
Lizard's Avatar
08.14.2015, 03:03 PM
You mean the purpose of being controlled by the remote? Yeah, well, the alternative would be to connect a laptop everytime to make adjustments, so an onboard torque control knob is a big improvement for me. Great that it should work with a servotester, I'll try that out :)
BTW: Is there anything planned with bluetooth and smartphones? Using a laptop on the field is annoying and the field link card only supports the basic options ...
mwe-maxxowner
mwe-maxxowner's Avatar
08.23.2015, 01:31 PM
Adjusting things via Castle Link over bluetooth would be AWESOME! Or for me through traxxas's remote and my phone.
Brushless-taking back rc!
E-revo is DONE!
  Send a message via AIM to mwe-maxxowner
Lizard
Lizard's Avatar
08.24.2015, 11:26 AM
I think that doesn't work with my TQi :( There are three pins inside, with nothing connected I get 1500us, with a jumper lead from the left to the middle pin I get 1000us, with the right one 2000us. Also tried with several different resistor values, always the same.
Mr E-Maxx
Mr E-Maxx's Avatar
11.05.2015, 05:45 PM
Hello,
Will the Aux function go to the Sanwa MT4 in the future too?
Kcaz25
Kcaz25's Avatar
12.05.2015, 02:06 PM
I finally got the time to order a Monster X! I wanted to take part in the promotion and review process but I didn't have time. Im pretty excited! USPS dropped it this morning! I won't be home until tomorrow afternoon.
Kcaz25
Kcaz25's Avatar
12.22.2015, 06:43 PM
Hey my AUX on my transmitter is only a toggle how can that adjust in increments of 10% is this only for radios that have more dynamic aux channels or can I adjust this with EPA?
Thanks!
