Cain
05.09.2009, 01:48 PM
little youtube of the hyper 9e spinning on a display stand:
http://www.youtube.com/watch?v=K4P51Uh2Uos
Marvin
THE Paranoid Android
Marvin's Avatar
05.09.2009, 06:42 PM
I'm pretty peeved at the moment.
I mentioned before I broke the shock top, but it seems that finding spares is impossible in the UK. I ordered 86050 which was listed as the correct spare.
However, whilst it 'just' fits the shock, it won't fit the mount as the hole is too small. So I looked for the right spare part, and after about 20 minutes came up with another, different part number for the same parts. Eventually, I found on Nitro House's website the right part (under hop-ups), so I typed the part number into Google....
Zilch, nothing came up other than at NitroHouse. I also tried it without the OFN part to comply with the rest of the world, and still nothing. I'm going to have to use different shock mounts or something.
I'm not best pleased right now that, finding the part no. is difficult enough, then actually finding someone with the part in the same continent as me is completely impossible. I should be racing tomorrow, but I guess that's down the drain now.
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
SnoopMaxx
SnoopMaxx's Avatar
05.09.2009, 07:37 PM
Hey Marvin Did you check the HoBao hyper 9 for compatible parts ? ?
Morten SnoopMaxx
Never to old to play
c",)
Marvin
Marvin's Avatar
05.10.2009, 04:01 AM
I'm not sure what you mean
Originally Posted by MetalMan View Post
Nitrohouse and Ofna are located in the same building, in case you were wondering.
It does explain a lot. Only problem is that I don't want to be ordering the parts I need from the US everytime a need anything, as I will get stung on import duty (at 15% of the item's value + a surcharge) - which sucks.
SnoopMaxx
SnoopMaxx's Avatar
05.10.2009, 02:58 PM
Did you look at the Hobao Hyper 9 manual to find the part you needed ?
From Singapore
Ofna Hyper Big Bore Shock Plastic Parts #86050
From UK
HOBAO HYPER 9 20mm BIG BORE SHOCK PLASTIC PARTS
Morten SnoopMaxx
c",)
MetalMan
MetalMan's Avatar
05.09.2009, 10:33 PM
Cain
05.10.2009, 08:23 AM
Thats strange that the part number you got was listed. On the manual I downloaded, its 29109 in the Hyper 9E parts section. You probably already have the manual now, but if not, you may want to download it and compare to what you got.
So, anyone recommendations on what I should pickup for spares? Any opinions on the durability of the 1 piece wing setup?
Marvin
Marvin's Avatar
05.10.2009, 09:03 AM
Yeah, it is 29109. But, I don't have the electric manual, not even those first couple of pages in the nitro one, only the nitro one, which originally came with different shocks. That part number is different.
The one-piece wing is fairly durable, but I have already got the standard type wing mount just in case. The back curved section has started to break off from the rest of the wing, so time will tell, though I am fairly rough on cars.
Cain
05.10.2009, 09:09 AM
Do you want the link to download it? Its on ofnas manual section.
Looking at the prices, seems 12.71 is a popular number for parts for the Hyper 9/9e . Even the optional wing mount costs as much as the 1 piece wing setup.
Marvin
Marvin's Avatar
05.10.2009, 09:12 AM
No, it's alright, that's where I actually found the right part number finally. The spares aren't all that sort of price in the UK (if you can find them); they are all different.
Cain
05.10.2009, 09:15 AM
Cool. Thats good though that the wing is proving to be fairly durable.
Cain
05.12.2009, 08:38 AM
what do you feel is the largest pinion you can use on the buggy?
I am thinking of trying an idea I have. using SMCs new 9000mah battery, in a 3S configuration, with a 2650 motor. there 9000mah is rated at 28C, so that would be 252Amps continous. I don't see why I would have any issues with that high of a C rating compared to what guys were experiencing with 3S and lower C ratings. potental energy in the pack is greater than a 5S 5000mah setup.
gixxer
gixxer's Avatar
05.13.2009, 01:38 AM
I dont think gearing is going to be an issue. I have a 17t on mine now with a 1300kv and have a lot of room left on the mount.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
brushlessboy16
brushlessboy16's Avatar
05.12.2009, 03:05 PM
17 or 18 would probably be the highest i would go in a buggy on 3s..
Cain
05.12.2009, 03:44 PM
I gear for 40mph max, so should be no worries there.
