Thread Tools Rating: Thread Rating: 10 votes, 3.60 average. Display Modes
Sammus
Sammus's Avatar
11.06.2008, 07:12 PM
My problem seemed like the batteries voltage was dropping so far it reset the rx (i could see the rx light go off and watch it reset), but i tried all kinds of high powered lipos and stuff too, the a123 were just the standard setup, and it happened with the motor not connected to anything as well - not even a pinion on it, I'm pretty sure A123 cells are up to spinning an unloaded motor without dropping below 1V/cell lol... I can't figure out what it is, and havent to this day. I've used the exact same setup in other cars without problem, it is really really baffling. Like I know there is something I'm not thinking of, and its really frustrating lol.. oh well.
11.06.2008, 07:14 PM
A few questions:
- Were you using a BEC or Rx pack?
- Were the rx pins dirty? Or, they may have a cold solder joint and making/breaking contact.
- Is the antenna sound? I had a Spektrum antenna that was flaky and had odd stuff happen until I replaced it. Was a PITA to solder though because of some coating on the PCB.
Sammus
Sammus's Avatar
11.06.2008, 07:23 PM
A few questions:
I tried an external and the internal BEC, and 4 different receivers. I don't own an Rx pack but I'm thinking I'll build something and try it soon. I'd hate to have to run an Rx pack though, and I still can't believe 4s1p drop that much with zero load... it actually seemed to glitch more when I was testing it unloaded, but it could just be my frustration imagining things lol... meh more testing when I have time.. I'll probably make some thread about it if I ever succesfully figure it out haha
brushlessboy16
brushlessboy16's Avatar
11.15.2008, 01:16 AM
Well my V3 should be here by monday. but i Think I eliminated the glitching problem
Spektrum Rx- I got from a trade for a charger, and some miscelaneous stuff
Module- I payed 60 Bucks for. So now im in the 2.4ghz club and I like it soo far.
And I just got done shortening the motor leads down to 4 inches. Esc will be mounted behind the motor on the chassis.
brushlessboy16
12.09.2008, 04:39 PM
Hey guys a bit of an update
Just ran the truck for 20 minutes, all wot, jumping speed runs etc.
at the end of the pack the motor was 110* esc was 120* and zippy batt was at 115*
This was geared for 43mph on 4s lipo :)
SteGra
12.09.2008, 04:48 PM
What is your gearing?
How does the Neu-Castle compare to the same Neu motor (performace-wise)?
Sorry for the questions, if they've already been answered in earlier posts but I am getting dizzy going through the previous ten pages of posts.
brushlessboy16
12.09.2008, 05:10 PM
Gearing is 16/66
for 43mph
I have never run the real neu, so I couldnt tell you
E-fanatic
Brushless only!
E-fanatic's Avatar
12.09.2008, 05:23 PM
I am having some heat issues with mine. Geared for 38 in an e-revo I am seeing 170+ on the motor. It has lots of power though!
brushlessboy16
12.09.2008, 05:28 PM
what are your settings on the MMM, what motor do you run
brushlessboy16
01.08.2009, 09:03 AM
Update:
All slotted rotor-motors(say that 5 times fast) Will be hard to turn by hand.
The maximum Shaft play is approximately 1-2mm
brushlessboy16
01.09.2009, 08:52 PM
Update:
All slotted Stator-motors(say that 5 times fast) Will be hard to turn by hand.
Thanks speedy :)
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
01.09.2009, 02:28 AM
To clarify, the rotors are not slotted, the stators are...
Area 52 Ranch Raceway
T.R.C.R.
brushlessboy16
02.07.2009, 12:55 PM
2200kv vs 2650kv
Rotors:
Cans:
E-fanatic
Brushless only!
E-fanatic's Avatar
02.07.2009, 02:52 PM
Originally Posted by coolrunnings
Someone made a voodoo doll of the mmm and there sticking pins in it....we just need to find the bastard!
Well, it looks like someone found him
So hows the the 2650 run compared to the 2200?
brushlessboy16
02.07.2009, 10:17 PM
The both run great. the 2200 is in my Matrix truggy on 4s, and the 2650 is in Eovnu87435ds's hyper 7 on 4s.. pretty sure neither has seen over 140 degrees
Tags
1515 1y, brushless, castle neu, mamba monster, mmm
