Thread: Schulze
lutach
lutach's Avatar
02.26.2008, 10:09 PM
The length of the cable from your batterie(s) is missing on your pictures.
This is from the manual i found on their website (translated from german):
. cable length to your motor should be 10cm
. The length to the batterie should never exceed 20cm
-> Exception: Schulze 18.97KWF (max 30cm)
If your cable length do exceed those values, then you must add low ESR capacitors to the ESC.
Hope this helps.
Mr. Schulze only asked for those though. I sent him an e-mail with the photos and I will wait and see what he'll say. If he does ask for a picture of the battery, I will take some. Thank you for the input othello.
