Schulze
othello
HV basher
02.26.2008, 09:26 PM
The length of the cable from your batterie(s) is missing on your pictures.
This is from the manual i found on their website (translated from german):
. cable length to your motor should be 10cm
. The length to the batterie should never exceed 20cm
-> Exception: Schulze 18.97KWF (max 30cm)
If your cable length do exceed those values, then you must add low ESR capacitors to the ESC.
Hope this helps.
Latest video with eagletree Data inserts:
Run on asphalt
othello
Find all posts by othello
