lutach
lutach's Avatar
03.31.2008, 08:46 PM
What is the current rating on the 100V? It's hard to say if the 0.01 ohm will matter, since there is usually less current flowing in a HV system the losses would be about the same as a LV but HC system with a lower resistance FET. Although 0.01 is about 5 times higher than average Rds for a FET.
The 100V has the following specs: 100V, 34A cont., 0.023ohms, Tr is 15ns and the Tf is 9.3ns. The FDS5672 has a Rds of 0.01. SO would 0.013 make a lot of differance?
