DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.21.2008, 12:13 AM
Originally Posted by TDC57 View Post
So does that mean to your going up to a 17T pinion or going down to 10T?. I'm asking because I’ve got the 1512 2d s (almost the same motor) I haven’t installed yet. I'm hoping to learn from you experiences.
What oil weight did you use for your center diff??. I used 30K
Thanks for your time DB..
Have a great Friday / Weekend..
Shaun.
The whole chassis setup is completly standard, shock oil/diff oil/shock springs/ride height etc. Just put all the electrics in, test at track and go from there. The standard diff weights in the 8ight are Front - 3000 Centre - 5000 Rear - 2000. Not sure what to do about the gearing yet, will run another battery through it and then try and decide what to do
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
