E-Traxxer
08.04.2008, 10:06 PM
Originally Posted by spaz163 View Post
Well it depends where you measure to. I just went and measured mine and I came up with 165mm (6.5") if you measure from the end of the pack to in between the balance and charge plugs. But if I measure from the end of the pack to the end of the shrink wrap around the charge plug leads I get 177mm (7").
So if you were using a low tray so that the balance and charge leads could just hang over the end of the tray, I would say 165mm and then use a velcro strap down the length of the pack in between the 2 plugs.
I have not been able to run this pack yet because of a faulty charger I recieved so I cannot give you any performance data on it yet. Oh and I have the 4s 4800 Zippy-R.
Thanks, that's the exact answer I was looking for.
It sounds like they are the exact dimensions of my TP packs. I am also going to be getting the 4s 4800mah. :)
Thanks again.
