E-Traxxer
08.04.2008, 10:06 PM
Originally Posted by spaz163 View Post
Well it depends where you measure to. I just went and measured mine and I came up with 165mm (6.5") if you measure from the end of the pack to in between the balance and charge plugs. But if I measure from the end of the pack to the end of the shrink wrap around the charge plug leads I get 177mm (7").
So if you were using a low tray so that the balance and charge leads could just hang over the end of the tray, I would say 165mm and then use a velcro strap down the length of the pack in between the 2 plugs.
I have not been able to run this pack yet because of a faulty charger I recieved so I cannot give you any performance data on it yet. Oh and I have the 4s 4800 Zippy-R.
Thanks, that's the exact answer I was looking for.
It sounds like they are the exact dimensions of my TP packs. I am also going to be getting the 4s 4800mah. :)
Thanks again.
tc3_racer_001
tc3_racer_001's Avatar
08.05.2008, 03:08 AM
so will this fit in a tray designed for the new enderland packs? (168mm compared to zippy's 170mm... personally i think they are using similar cells.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
ffactory666
08.05.2008, 03:48 AM
Wont fit because they are 50m wide.
I just had Mike make me two custom trays so i could fit my new PQ pack ( Enelrand cells ) and Zippy packs.
E-Traxxer
08.05.2008, 04:19 AM
The Zippy-Rs are stated to be 45mm wide...
Are they really 50mm?
ffactory666
08.05.2008, 06:34 AM
My bad , sorry . Mine are the H packs not R
