08.28.2008, 08:49 PM
Originally Posted by JerryF504 View Post
So now basically it's an opto ESC?
Basically yes. Although, in most Opto ESCs, you still need the main battery connection as well.... at least that's how it is in the CC HV ESCs.
Originally Posted by TruckBasher View Post
Whoah nice one Brian.....I hope I am good with soldering iron as you are....
You'd laugh if you saw the iron I worked with. Since I knew those parts were destined for the trash, I heated one side of the IC while gently prying with a tiny screwdriver. The IC basically fell off when I heated the other side. I just cut the inductor out and then removed the leftover connections.
I see the fan plug went south too
Of course! I wasn't using it anyway and it was added weight for nothing.
Brian just created the first MMM lite...
$10 says it still conks out...
Let's see how long it lasts. I got this ESC really cheap, so if it blows, no biggie. It was more or less my experiment ESC. I've never blown an ESC yet, and I hope not to change that, so hopefully things will be good. The only things that can go wrong now is if the external UBEC fails (sending full B voltage to the internals - ouch!), or if the ESC simply decides to do a Schulze on me.
And neil, I have one thing to say to you:
