Pdelcast
Pdelcast's Avatar
08.28.2008, 05:02 PM
Patrick, to be totally clear, the components to remove are the ones in the pic below correct? This will completely disable the built-in BEC? I would;ve thought that just removing the coil would be enough...
I know I'll have to "inject" external 6v power into the MMM throttle power line so the internal circuits can have their power.
Those are the right parts.
Patrick del Castillo
President, Principle Engineer
david lamontagn
08.28.2008, 05:28 PM
BrianG, Patrick tell me that the internal BEC of the MMM have a 3.3 volts regulator to power the microprocessor of the MMM, so if you powered it with the 6 volts of your Koolflight UBEC, you risk to destroy your MMM
08.28.2008, 05:31 PM
Thanks Patrick!
David: No, I'll be injecting the 6v into the throttle lead back into the MMM, which is normally at ~6v anyway. The additional 3.3v regulator must be further back in the circuit.
Basically, I'll be using an external UBEC without pulling the red wire...
08.28.2008, 07:43 PM
Success!
Removed the components Patrick suggested and it works like a champ.
The MMM switch is useless now, switching it off did nothing. So I bridged the contacts at the PCB (did this after the pic above).
And now, I can use the Castle Link without any mods, nor do I need batteries hooked up to the ESC. I don't know if this mod makes anything run longer or better, but I feel better with my V1.
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
08.28.2008, 08:01 PM
Success!
So now basically it's an opto ESC?
TruckBasher
TruckBasher's Avatar
08.28.2008, 08:19 PM
Whoah nice one Brian.....I hope I am good with soldering iron as you are....
E-Slayer direct drive to diff
08.28.2008, 08:23 PM
I see the fan plug went south too
08.28.2008, 08:27 PM
Brian just created the first MMM lite...
08.28.2008, 08:35 PM
$10 says it still conks out...
08.28.2008, 08:49 PM
Basically yes. Although, in most Opto ESCs, you still need the main battery connection as well.... at least that's how it is in the CC HV ESCs.
You'd laugh if you saw the iron I worked with. Since I knew those parts were destined for the trash, I heated one side of the IC while gently prying with a tiny screwdriver. The IC basically fell off when I heated the other side. I just cut the inductor out and then removed the leftover connections.
Of course! I wasn't using it anyway and it was added weight for nothing.
Let's see how long it lasts. I got this ESC really cheap, so if it blows, no biggie. It was more or less my experiment ESC. I've never blown an ESC yet, and I hope not to change that, so hopefully things will be good. The only things that can go wrong now is if the external UBEC fails (sending full B voltage to the internals - ouch!), or if the ESC simply decides to do a Schulze on me.
And neil, I have one thing to say to you:
08.28.2008, 09:47 PM
Impressive work Brian!
joeling
joeling's Avatar
08.29.2008, 11:10 AM
Can I nominate this to be a sticky ? BrianG is a legend. I have just done this mod to my dead V1 & magically, the esc has been resurrected.
Before
After
Regards,
Joe Ling
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
TruckBasher
08.29.2008, 11:12 AM
I hope this is applicable to V2......just in case mine dies ( I hope not too soon )...
08.29.2008, 11:38 AM
Don't forget to remove the switch wires and bridge the solder pads where the switch goes. I did a little more testing with the switch in place and found that when it was off and ran it for a couple of minutes, I'd have odd performance. Something like cogging, but not. With the switch closed, everything runs perfectly. So, you might as well remove it and bridge the pads. Cleans up the wiring too.
joeling
joeling's Avatar
08.29.2008, 11:45 AM
Yep, curious me already tried that. Not good to have the switch opened.
Thanks.
Regards,
Joe Ling
