Gee
A Horse's Ass
Gee's Avatar
11.29.2008, 04:52 PM
Like redshift said, it's best to get premade ones in this case.
That takes hobby out of hobby. That would be like buying revo already converted instead of using all the part you already have to convert your own. No challange, no appreciation for what you've done, and you didn't learn nearly as much as if you done it yourself. That's just me. I like to try and adapt things to fit other purposes. It would be hard to go out and buy new lights when you have all of these play with.
I used the (Vs-Vd)/i to come up with what resistors to use on the various led and lights I set up. They do dim a small bit but they a least tell me which way it's going. Pictuers don't do them justice. They look real pretty cool at night.
Quick set of light on the 8ight
Something different on the new rustler chassis
Emaxx setup - also doubles on the slash at night.
Thanks for the verification on the setup. Sounds as if the LED is the smallest fuse I could get. I can work with that.
