dangerwr
01.18.2009, 07:48 PM
Originally Posted by ssspconcepts View Post
Yep...had to use the 8mm DM-1 Spec center shaft...that's why you will need the 8.1mm inner diameter steel tubing.
I see--would you mind sending me PM with how much you would like for some of the 8.1mm tubing? I might have some in our machine shop at work but highly doubt it will be the exact size. Just let me know . . .
