Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
ssspconcepts
ssspconcepts's Avatar
01.18.2009, 07:33 PM
Originally Posted by dangerwr View Post
I bought one of those Hotwheels radar guns off eBay for $20 and works pretty good! I am going to gear mine around 60mph at first and see where the temps are with my driving style.
Now, on the solid center spool I wound up using the center shaft and outdrives from the 2-speed that came with the car and not the little kit. Did you do the same or did you do something different?
Yep...had to use the 8mm DM-1 Spec center shaft...that's why you will need the 8.1mm inner diameter steel tubing.
dangerwr
01.18.2009, 07:48 PM
I see--would you mind sending me PM with how much you would like for some of the 8.1mm tubing? I might have some in our machine shop at work but highly doubt it will be the exact size. Just let me know . . .
