04.17.2009, 04:31 PM
Harold pointed out the place to get the motor and the pinion can be found at https://sdp-si.com/eStore/, click on metric go to spur gears and use the drop down boxes to select the following: 1.5, With Hub & set screw and the bore size.
Gotta watch them... I ordered 8mm bore 1.5mod 12t pinions for my baja and selected w/hub and setscrew and they showed up without any setscrews, or the drilled/tapped holes that a setscrew would go into... Good thing I have a drill press...
