Thread Tools Rating: Thread Rating: 9 votes, 4.11 average. Display Modes
coolrunnings
04.17.2009, 03:32 AM
That looks awesome. What does it weigh with packs? It looks like it would be super light.
I couldn't convert my baja though. It works so well as it is. I didn't even like the baja that much until I got one. The little 2 stroke goes and goes. I have tried to kill it trust me but it just keeps going. It's by far the most reliable rc I have.
It weighs right around 20 pounds or more, about same as the stock rtr but with a much lower CG and tons of power. Price wise I wont mention what I have in it, cause I get sick even thinking about it...lol. You can do one without spending 5 grand though.
brushlessboy16
brushlessboy16's Avatar
04.17.2009, 09:26 AM
I think the right motors for 1/5 scale are the big Neu 22xx, Plettenberg Bolido and the Lehner 36xx. I also think Astro Flight has some low Kv big inrunners too and when the appropriate ESC comes out they should be a good motor too (Actually they are really low Kv and might not work).
I like the looks of the bolido, but do you know where I can get more info on it? Its neat that its a direct fit for an fg pinion which is also mod1.5 and makes life easier
04.17.2009, 10:34 AM
Here you go http://www.icare-rc.com/plettenberg_pricelist.htm#cars
good luck on that, its a tad spendy
Fast5sRevo88
04.17.2009, 03:02 PM
Is there a target price for the conversion kit?
lutach
lutach's Avatar
04.17.2009, 03:46 PM
Harold pointed out the place to get the motor and the pinion can be found at https://sdp-si.com/eStore/, click on metric go to spur gears and use the drop down boxes to select the following: 1.5, With Hub & set screw and the bore size.
04.17.2009, 04:31 PM
Gotta watch them... I ordered 8mm bore 1.5mod 12t pinions for my baja and selected w/hub and setscrew and they showed up without any setscrews, or the drilled/tapped holes that a setscrew would go into... Good thing I have a drill press...
lutach
lutach's Avatar
04.17.2009, 06:09 PM
Good to know, but it hasn't happened to me yet. Thanks for the heads up. Did you get the carbon steel ones?
MetalMan
MetalMan's Avatar
04.17.2009, 11:59 PM
I just got a $60 order from SDP-SI today, including belts, pulleys, and a gear. Everything which was supposed to have a set screw did. Did you recheck your order to verify that you ordered the gears with the hub/set screw and not hub/no set screw?
04.18.2009, 01:12 AM
Yup...
I double checked the part number on the invoice and packet to the online info and I ordered the correct thing. Must have been packaged wrong. No bother really. The 8mm bore mod 1 pinions I ordered cam with a setscew so small I had to use the pointy end of a dental pic to unscrew them. What a joke. I will have to drill them out and tap them for m4 thread as well. I may drill the mod 1.5 pinions out for m5 or m6 thread, they will need some strength and the 1521 motor shafts are 8mm...
MetalMan
MetalMan's Avatar
04.18.2009, 03:13 AM
It's true, some of those set screws are extremely small. Thankfully we have drill presses...
BitHed
05.07.2009, 09:24 PM
...looks great...makes me reconsider doing my own one...its the size that kills me though...i want the HPI Baja in like a 1:10 size, or kinda like between a 1:10 and a 1:8...These comments are not directed at anyone in particular and in no way should be misconstrued as a complaint or a request :D
drkros3
05.22.2009, 03:11 AM
any updates on this kit. i have a baja that just sits here and would love a brushless in it lol.
Byte
05.22.2009, 04:30 AM
Lol, it's funny that this brushless motor costs 100 dollar less in the EU. Mostly all things are cheaper in the US than in Europe..
RcZoNe444
05.24.2009, 08:12 PM
That Baja is insane, I can't wait for a electric conversion to be on the market for the Baja. Then I might get one.
Ryu James
Ryu James's Avatar
06.14.2009, 08:35 PM
whats the latest on this baja conversion? any videos yet? i would really like to see some detailed close up pics too.
would a neu 2230 fit in a 5b or 5t or is it too long? or too much power anyway?
Jammin SCRT10 Neu 1512 1y
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
