GriffinRU
12.18.2005, 11:07 PM
I like this version better than your last version. No offense intended. Your batterys are pretty low do they hit the ground ?
Good input always welcome!
First one has its benefits as well.
I build battery housing to be strong, to protect future LiPo cells. So, yes it does come in contact with ground but nothing to worry. That how it looks after 10+ runs
I built it from 3 parts, if you do the same as one, then you can level battery cover with f/r skidplates. But if you worry about ground clearance then my first setup would be better.
Artur
P.S. Try to put 6 cells between front and rear skid plates. You will get better picture of what I am talking.
