hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
04.02.2010, 07:04 PM
Can't wait to give the other 10th scalers some brushless a$$ kicking!
found these 17mm adapters in my random parts box that fit the ten-t's axles perfectly....just needed some washers to keep the wheels from backing out.....and..these adapters should fit as well
http://www.amainhobbies.com/product_...-T-Maxx-Blue-4
the ID is 6mm but the pin that comes with it is 3mm...you can either drill out the ten-t's axle or use the ten-t's axle pin (its 2.5mm)
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
