Originally Posted by BP-Revo
DE3175 31mm festoon bulbs.
I replaced them with festoons that have 4 LED on them. My door lights (they are on the bottom of the door to illuminate the ground when you open the door) use similar bulbs and there are no issues there...along with the 9 other lights around my car I replaced with LEDs. It's just the map lights when it auto mode - if I don't use auto mode (lights off unless I turn them on manually), the are 100% off and then turn on 100% when I manually turn the lights on by pressing the light itself (they work perfectly fine). Only in the auto-door mode do I get a bit of residual glow.
the same thing happend when i replaced the bulbs in my mazdaspeed 6, after reading around alittle bit i found out it a common thing now days and it hasnt caused any problems for over a year, voltage draw over the ACC circuit was the same with both bulbs according to my fluke
