BP-Revo
BMW M Power!
BP-Revo's Avatar
04.10.2010, 01:37 PM
Originally Posted by squeeforever View Post
Honestly man, I don't know of to many options. I've seen the problem before, but for some reason only on map lights. What kind of bulbs do the map lights use? Festoon? Rigid loop?
DE3175 31mm festoon bulbs.
I replaced them with festoons that have 4 LED on them. My door lights (they are on the bottom of the door to illuminate the ground when you open the door) use similar bulbs and there are no issues there...along with the 9 other lights around my car I replaced with LEDs. It's just the map lights when it auto mode - if I don't use auto mode (lights off unless I turn them on manually), the are 100% off and then turn on 100% when I manually turn the lights on by pressing the light itself (they work perfectly fine). Only in the auto-door mode do I get a bit of residual glow.
