04.13.2010, 04:42 PM
It could be a timing thing - wondering if the ESC can cope with that many pulses at full voltage with a 4 pole motor...
Suspect at flat out that the timing is going up the wazzoo causing the motor to heat up...
Does it exhibit the same behavoir when not under load i.e. on the bench?
