superek4
superek4's Avatar
05.11.2010, 07:54 AM
0 timing is not a good idea I suggest u gear down. Or change the motor. Kd motor is 2pole. 4pole is better.
Esc seldom overheats unless fan spoil.
Originally Posted by Chadworkz View Post
I am running a HobbyWing eZRun 80A ESC, KD36-74-1900kV Motor (with Turnigy Heatskin & Fan), and a pair of Zippy 30C 4S 2650mAh LiPo Batteries wired in parallel (4S-14.8V @ 5300mAh & 159A) in my Dad's E-Revo (stock except for Pro-Line Maxx Mulchers on Pro-Line Velocity 23mm ½" Off-Set Wheels with Dace Mfg. 23mm Hex-Adapters) geared for 38mph...
I have left most of the ESC settings on default, except setting the Timing to 0° and the Punch to 50%, but I have heard running 0° of timing is actually a bad thing...is this true? Default is 15°, but since the KD motors are known to run warm, I set the timing to 0° in order to keep it cool. I have never had any overheating issues, but would just like your input on the timing, and anything else you would like to add.
Thanks in advance...
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
