05.11.2010, 07:54 AM
0 timing is not a good idea I suggest u gear down. Or change the motor. Kd motor is 2pole. 4pole is better.
Esc seldom overheats unless fan spoil.
Originally Posted by Chadworkz
I am running a HobbyWing eZRun 80A ESC, KD36-74-1900kV Motor (with Turnigy Heatskin & Fan), and a pair of Zippy 30C 4S 2650mAh LiPo Batteries wired in parallel (4S-14.8V @ 5300mAh & 159A) in my Dad's E-Revo (stock except for Pro-Line Maxx Mulchers on Pro-Line Velocity 23mm ½" Off-Set Wheels with Dace Mfg. 23mm Hex-Adapters) geared for 38mph...
I have left most of the ESC settings on default, except setting the Timing to 0° and the Punch to 50%, but I have heard running 0° of timing is actually a bad thing...is this true? Default is 15°, but since the KD motors are known to run warm, I set the timing to 0° in order to keep it cool. I have never had any overheating issues, but would just like your input on the timing, and anything else you would like to add.
Thanks in advance...
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
esc unprogrammable -
05.11.2010, 02:23 PM
Hi,I've emailed hobbywing several times,no reply  .A nd the eshop I got it from,same outcome. My esc is set on max everything,acceleration,brakes,etc.Its undrivable in my mlst2. I've seen you can programme it from your computer,but I've not got a usb lead. Any ideas? Any help is appreciated
05.11.2010, 05:33 PM
Have u tried using the program card? It does not need a USB port
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
UE Supermaxx Addict!
05.11.2010, 06:17 PM
Definitely buy the program card, it makes programming super easy, easier than using your computer!
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=8996
You can buy the cheaper programming card, but it just isn't very good, and the one above is awesome! I have both of them, so I can make the personal comparison.
-Chad
› PM ME IF YOU HAVE THE BELOW:
› VBS, CVDs, GM Single-Speed, OTB, Ultramaxxed, Super6, Strobe, Sprong, CNR Brake, UE Hex, DUH Towers, Predator, Blackbird, GA Blue Screws, HCR F/R Skids & Mutant
05.11.2010, 06:47 PM
yes I hv both of the programming card. The one above is better.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
05.13.2010, 10:31 AM
can u tell me more about your setting?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
Thanks for the info! -
05.14.2010, 08:41 AM
Hi, My esc's ste on max every thing,brakes,acceleration,everything! It's wrecked several diffs, and bodies. I need just to turn it down a bit(never thought I'd say that)  . As ever any info is appreciated
05.14.2010, 09:42 AM
Did u reset the esc n try again? Did u manage to get another card to try?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
Hobbywing 150A esc and Neu-Castle 2200 motor. -
05.20.2010, 05:56 PM
Hello.
I have this combo and woundering how to wire them together. On the Esc it says A,B and C and on the motor there is one red,black and White wire. Where do they go..
Dill
05.20.2010, 06:47 PM
Originally Posted by dilldozer
Hello.
Dill
It's a sensorless motor so any wire is fine, it won't burn up the motor. If it run reverse just swap 1 wire again.
The only time u need to follow ABC on esc n motor is on sensored motors.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
