simplechamp
simplechamp's Avatar
07.20.2010, 07:17 PM
Yeah I get how EPA works, but how does the max throttle limiter work? I just assumed it did the same thing as lowering EPA. So if you set the throttle limiter to 75%, is that accomplishing the same thing as turning the EPA down to 75% (providing you calibrated the ESC with EPA at 100%)? I guess with the throttle limiter you would still have the full range and resolution of your throttle trigger?
