simplechamp
simplechamp's Avatar
07.20.2010, 07:17 PM
Yeah I get how EPA works, but how does the max throttle limiter work? I just assumed it did the same thing as lowering EPA. So if you set the throttle limiter to 75%, is that accomplishing the same thing as turning the EPA down to 75% (providing you calibrated the ESC with EPA at 100%)? I guess with the throttle limiter you would still have the full range and resolution of your throttle trigger?
nuz69
nuz69's Avatar
07.20.2010, 07:24 PM
IMO the torque limiter is in fact a current limiter. Concerning the power limiter, if the power is too limitated i suspect the ESC to heat a little more than usual. That could explain why with this firmware the fan is always ON...
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Pdelcast
Pdelcast's Avatar
07.20.2010, 08:10 PM
The torque limiter is not exactly a current limiter, but it works similarly (the difference being that the torque limiter isn't reactive -- in other words, it doesn't react to changes in current, it actively controls torque, which in effect controls current...) Make sense?
Patrick del Castillo
President, Principle Engineer
