Pdelcast
Pdelcast's Avatar
07.22.2010, 08:03 PM
Originally Posted by Dadx2mj View Post
With the "fixed" new release of the software I was able to update the other two Mamba Max ESC's in the house through the USB port with out issue. Both ESC's are working fine and later I was able to change the settings using the USB port so the fixed software seems to have cured the issues with the USB port on the MM.
Yep -- just a silly bug in the release. Everything should work fine after update.
Patrick del Castillo
President, Principle Engineer
