Dadx2mj
Dadx2mj's Avatar
07.22.2010, 04:36 PM
Originally Posted by crazyjr View Post
Thanks Patrick, One more question. If i can unbrick this esc, Will it still be able to use the USB on the side? Or, Will it be limited to using the card/castle link to program? Doesn't matter either way, Just wondering
With the "fixed" new release of the software I was able to update the other two Mamba Max ESC's in the house through the USB port with out issue. Both ESC's are working fine and later I was able to change the settings using the USB port so the fixed software seems to have cured the issues with the USB port on the MM.
Blindman Racing
Powered by Mamba 5700
