Thread: My New Build
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.31.2010, 08:38 PM
Interesting shock set up ? Do you think the four little shocks will enough for the complete truck ? It's still gonna be 10-11lbs when complete, I was woundering if a heavier duty front buggy 1/8scale shocks might be better ? IDK.
Yes, very Revo-ish, I really like the looks of the lay out.
Very nice job of fabricating my friend.
You could also swap sides and turn around the rear arms so the rear shocks would be on the other end as well ? Lot you can do with how you put everything together, pretty slick indeed.
EDIT, what size bolts did you use for the pin replacement. I really like that idea even tho I never had probs with loosing E-clips.
