Thread Tools Rating: Thread Rating: 47 votes, 5.00 average. Display Modes
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.31.2010, 08:38 PM
Interesting shock set up ? Do you think the four little shocks will enough for the complete truck ? It's still gonna be 10-11lbs when complete, I was woundering if a heavier duty front buggy 1/8scale shocks might be better ? IDK.
Yes, very Revo-ish, I really like the looks of the lay out.
Very nice job of fabricating my friend.
You could also swap sides and turn around the rear arms so the rear shocks would be on the other end as well ? Lot you can do with how you put everything together, pretty slick indeed.
EDIT, what size bolts did you use for the pin replacement. I really like that idea even tho I never had probs with loosing E-clips.
redshift
RC-Monster Square Tube
redshift's Avatar
07.31.2010, 08:58 PM
Those are the ST Racing set, 4mm shoulder bolts. They're kinda pricey but I ponied up the cash for them because I have a longstanding hatred of e clips
I actually had the rear shocks on the rear side, but decided they'd be much better protected on the front.
As for the Bigbores, they have worked extremely well in the 15 or so test runs I've done so far. I did intend to get a set of Ofna shocks, but these are working so well I've stopped thinking about changing them. The preload spacers are not on them in the pics because the boots need replacing and they need to come apart again. The rear squats the slightest bit on throttle stabs, which makes it less wheelie-prone. But the 1520 on 6S will throw it up
with it's 14.4" wheelbase still. It's geared for roughly 38 mph and it gets there in about 10 feet, way impressive. The motor and MMM are barely cracking 100 or 105 the whole run. I haven't weighed it yet magman, but with the 1520 weight is really not an issue
Fast5sRevo88
08.01.2010, 12:23 PM
pissed myself
