Thread: Soldering jig.
mjosparky
Sparky
mjosparky's Avatar
02.07.2011, 03:38 PM
Originally Posted by maneba View Post
I've bought it but it's useless.
The jigs subtracts heat from the connectors you are welding (not the case of the deans) and this is a bad thing. Worst 20$ spent in rc equipment.
How can plastic draw heat from the connector? All I use it for is deans. It allows for a quick, clean joint with having to hold a hot wire with your fingers. If you feel it is useless I think you may be using it wrong.
Sparky
Sharpchuter 245
Dyna Wide Glide
