03.25.2011, 11:40 AM
Originally Posted by J57ltr View Post
The only ones I have delt with are ones that the shaft has come loose and had to put them back on, but I think you could probably get the shaft hot and see if you can press it off. If it were me I would use a torch on the end of the shaft. I am sure you would have to be careful not to get it so hot that the rotor expands and shatters the magnet.
My issue with heating the shaft is that it will expand, and I really want to shrink the shaft, or exand the magnet. Pretty sure you are not supposed to get the magnets over 200f, so I will try to get it up to 180 or so, while it is setup in the press. If I destroy it I do not care, it is useless as is.
