brian015
brian015's Avatar
04.19.2011, 02:30 PM
What do i do???
I do not want to cut the wires? as that will cause a bottle neck of power and result in heating up the end?
I don't think you need to worry about this if you trim the exposed wires a little to make them fit. The current will not only flow out of the end of the wire into the connector, but also through its exposed sides.
