Hi guys...
Im approaching the end of my build and need to work out the electrics...
NEED SoME HELP AND ADVICE
Firstly.
I was trying to solder my ESC Bullets but ran into a prob straight away...
The bullets castle creation 6.5mm bullets are too small for the tinned ends of the ESC! So i cant connect to my motor wires!
Even my 5.5mm bullets do not fit onto the tinned ends to connect to my lipos
What do i do???
I donot want to cut the wires? as that will cause a bottle neck of power and result in heating up the end?
Do i drill the bullet out?
Second Query.... Regards to my BEC, My Twin Servo, ESC etc and my RX...
How does this all connect up??? Mainly in relation to the BEC
Obviously my ESC wire goes into ch2 of the RX and my steering goes into CH1
But with the BEC.... how does that connect to the servos? I use two servos... one for steering and one for my mech brakes
Also... in order to power my BEC, should i solder the power wires directly into the ESC 5.5mm bullets?
THANKS A LOT!
