Dj_Sparky
05.24.2011, 03:43 AM
correct. you'd need your bearing hole and your outside layer of aluminum would need a SMALLER (you said larger) hole so the bearing couldn't pop out.
Ops well yeah I meant a smaller. :P Thanks. That would be easier to do with just a thin layer of alu. Wouldn't be that hard to make a somewhat thick layer with bearing sized hole, and another thin layer of alu with a smaller hole and just screw it onto the larger layer.
