05.24.2011, 03:29 AM
Originally Posted by Dj_Sparky View Post
The 2nd hole in the diff. mount is to prevent any movement, right?
correct. you'd need your bearing hole and your outside layer of aluminum would need a SMALLER (you said larger) hole so the bearing couldn't pop out.
Dj_Sparky
05.24.2011, 03:43 AM
Ops well yeah I meant a smaller. :P Thanks. That would be easier to do with just a thin layer of alu. Wouldn't be that hard to make a somewhat thick layer with bearing sized hole, and another thin layer of alu with a smaller hole and just screw it onto the larger layer.
05.24.2011, 05:03 AM
that would do it. definitely a way to get around not having the right tools. good thinking!
Bmr4life
05.24.2011, 06:27 AM
It may be a little difficult to achieve a perfectly round hole with a drill bit though. You'll want to use a center punch and several smaller drill bits working your way up to the final hole size.
Dj_Sparky
05.24.2011, 08:32 AM
What tools are usually used for such work? Got a link to a setup?
