Originally Posted by A RC Dude
The start power is all the way up and it did in one 3 65C batteries and 2 motors...still can't go anyware below that speed. Castle has is and i'm working on getting my receipt to have it replaced (LHS closed down)
The removable rx wire would be a defect in the thickness of the pins or inserts in the wire plug, It was also one of the first run ESC's i think to where the problem may have been fixed already. I solved the wire problem by bending the 3 pins different directions so they hold pressure and then used a zip tie to prevent it from coming loose
Can you post up the setup you are seeing difficulty with? We just haven't seen an issue like this before. I'd like to have our engineers see if they can reproduce in the lab.
Thanx!
