A RC Dude
A RC Dude's Avatar
07.14.2014, 02:52 PM
Thanks for the feedback !!
Hadn't seen any issue with the removable RX wire yet -- that's interesting that you are seeing it come loose. I'll have the engineering team here look at that and see if there's anything we can do to fix the issue on this side.
The start power issue is probably just that -- start power is set too low for your particular motor. Have you tried bumping it up?
Thanks!
Patrick
The start power is all the way up and it did in one 3 65C batteries and 2 motors...still can't go anyware below that speed. Castle has is and i'm working on getting my receipt to have it replaced (LHS closed down)
The removable rx wire would be a defect in the thickness of the pins or inserts in the wire plug, It was also one of the first run ESC's i think to where the problem may have been fixed already. I solved the wire problem by bending the 3 pins different directions so they hold pressure and then used a zip tie to prevent it from coming loose
