Need help deciding on a good brushless system!
kingiggy262
BL-Revo
Need help deciding on a good brushless system! - 03.18.2008, 07:55 PM
Hey guys I am trying to decide what brushless system to upgrade my MM/8XL on my Revo with. The Feigao 8XL gets hot and just doesn't seem to run smooth enough for me. I was thinking that I could sell the motor and get a Neu 1515/1Y using my current 4s 8000 maH lipo's. If I did this then I would just keep my MM.
My other option was to go much higher voltage and use 8s 4000maH lipos with a Neu 1515/2Y and a Jazz 55-10-32 esc.
I know the 8s setup would be the most efficient and probably run smoother than the MM with the 1515/1Y but the price is what is holding me back from going the 8s route. Does the 1515/1y run smoother than the Feigao 8XL with the MM esc?
Any other suggestions are welcome! Thanks
Happywing
03.19.2008, 06:25 AM
So you have the latest firmware (1.17) loaded on your MM? If not, that upgrade will smooth it out. Is your motor direct-soldered to your ESC? That helps. The Feigao should run as smooth or smoother than a Neu. The Neu would run a lot cooler. If you want a Neu, why not wait for the MMM. That way you get motor and ESC for $300.
steve050773
03.19.2008, 10:10 AM
I would go 1515/1y with your current setup. Its used successfully by a lot of conversions on this board. If you try it out and aren't happy with it, sell it and try option two. You would probably recover a very good percentage of the motor's price.
kingiggy262
BL-Revo
03.19.2008, 11:23 AM
Good point! I think I will just try that then.
kingiggy262
BL-Revo
03.25.2008, 11:44 AM
Received the 1515/1Y today and I have to say that this is one awesome motor! I think that this motor actually runs smoother than my Feigao 8XL on the MM with the new firmware.
Thanks for the help guys!
