Mamba max pro esc, what motor?
Moller123456 !
Mamba max pro esc, what motor? - 06.21.2010, 06:54 PM
Hello RCM(F) i have a slayer, and i wanna put some brushless in it:) I have a MMP esc laying around, but only small 540 size motor, that wont be great for the slayer.
My Question is: What motor would you recomend? are any from Http://www.hobbycity.com Good? if not, can i then run mamba moster motors with the mmp esc?
Please help me abit:)
  Send a message via MSN to Moller123456 !
Kcaz25
Kcaz25's Avatar
06.21.2010, 06:56 PM
Yes, I would run a CC 2200 on 4s.
Moller123456 !
06.21.2010, 07:02 PM
Thanks:D would still like to know if anyone will recommend one from hobbycity, so i can save some money;D
alport
06.21.2010, 07:27 PM
I don't recommend hobbcity motors they are very hot. You can go for novak ballistic 550 or tekin's new releasing short course motors so your esc won't have any heat issues, you will have sensored advantages and enough power.
Moller123456 !
06.21.2010, 07:46 PM
that was what i thourght.
But thanks:D
ps. i have mod'ed the fan so it runs of the BEC power:) so i hope it runs cooler
Moller123456 !
06.21.2010, 07:49 PM
can i also use the xerun 2000kv motor with the MMP esc?
alport
06.21.2010, 07:59 PM
If you don't care about sensored drive A motor around 1600-1800kv with 5-6s would be a good choice too because of the efficiency and low amp draw. Probably a feigao 10xl(for 5s) or 11xl(for 6s) would be most cost-efficient motor if you're low on budget.
Moller123456 !
06.22.2010, 09:56 AM
would like to stay on 4s;) then i can use the same batt's in my ten-te and slayer:) But thanks:D
scarletboa
scarletboa's Avatar
06.22.2010, 01:47 PM
that motor should work just fine. the xerun motors are very efficient compared to their older motors. it won't be quite as good as a Castle 2200kv motor, but it will still run cool in your slayer.
Moller123456 !
06.22.2010, 06:33 PM
i have the xerun, and have tried a mamba monster 2200kv in my old slayer:) I just didnt wanna burn out my esc
scarletboa
scarletboa's Avatar
06.23.2010, 02:15 AM
you're fine as long as you don't gear too high. try to shoot for 35-40mph.
