This is not Good
George16
Supermaxx
George16's Avatar
This is not Good - 11.08.2008, 02:32 AM
Well, I'm trying to install the MMM on my revo today. But before doing so, I installed some heat shrinks on the bullet connectors just to be safe. Everything went fine except when I got to the positive power wire. I can't slide the heat shrink on. It seems that the bullet is either too close or already touching the heat sink. The male connector was also hard to insert because it was rubbing against the case.
Here are some pics:
Motor to ESC bullet:
Positive power wire bullet:
No problem putting a heat shrink on the neagtive terminal:
I did not open the case to fix the problem. It seems that the bullet was not vertical when it was soldered to the board. I know that it will rub due to vibration and impact later on but we'll see how long it will last. The only modification I did was to lengthen the wire for the switch.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Sammus
Sammus's Avatar
11.08.2008, 02:41 AM
No offence or anything, but is there anyone here (except myself) who believes Patrick when he said they tried shorting the connectors on the heatsink and it didn't harm anything???
If the "issue" has been brought to castle's attention, and they claim they have considered it and torture tested this units, with this particular possible point of failure in mind, and it survived with no harm, why question them?
That said, I have 3 V2's box stock that haven't missed a beat, so maybe I have undue faith (I seem to be having better luck than anyone else out there)...but I don't reckon you should worry about it
George16
Supermaxx
George16's Avatar
11.08.2008, 02:58 AM
I am not questioning them. I'm just saying that the bullet was not true vertically when it was soldered to the board. The negative terminal is fine and has about 2mm of clearance. Since it is leaning towards the case, it is being push away from the case when I inserted the male connector. This could mean undue stress on the board to bullet connection.
Now this is questioning. Aren't you an engineer? If you are, then you should know what happens when there is stress being added into a connection or joint, be it mechanical or electrical :.
Revo with OS .18TZ
JThiessen
JThiessen's Avatar
11.08.2008, 12:10 PM
Everything is subject to some amount of loading (the proper term here, since we don't know the exact nature of this loading). Its not until that load is too large for the parts to react that your devils will come out.
J3110
11.11.2008, 06:53 AM
That is exactly how I feel about the tight connections as well. Went through the exact same song and dance minus putting the shrink tubing on the connectors. Not too keen on the idea of mechanical stress on a solder joint, myself.
I almost feel like I'm being whiney or something after all the flak castle's taken for the failed units and I should just shut up and be happy it works.
At any rate, I will remain unhappy about that little detail and only hope that if it is going to result in a failure that it happens within the warrenty period.
Once the warranty is up, I'm crackin the case and "fixing" anything I think needs fixing.
I am sure that as far as castle is concerned, there's nothing wrong with these points.
Sammus
Sammus's Avatar
11.08.2008, 03:53 AM
Ahh I see what you're saying. Point taken
pasan
I <3 RC
pasan's Avatar
11.15.2008, 09:10 AM
I too did the heat shrink thing today, but only to the battery terminals. I shrunk the bits halfway so that they slid all they way down the connector, because if you take a good look you'll see they're recessed quite a bit inside, and the space around it is extremely tight.
Well castle have dropped the ball on the mamba monster, in all honesty. Considering how well engineered the mamba max is, it's no surprise people were/are expecting the same level of quality with the monster. You can almost say they brought it on themselves, considering how long ago this was announced to the public, and the anticipation involved. I myself received one of the few V2s with the 1.18 FW but thankfully nothing has gone wrong yet, even after the 1.20 upgrade.
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
11.15.2008, 11:52 AM
George16 - You lengthened the wires on the switch? why? Your best bet would have been to cut the switch off, twist the wires together and solder them! I used the switch at first, then it cost me a chance at being a contender at the RC-M Bash! The switch was turned off twice in the main, I had to run out on the track flip it on and run back to the drivers stand.
Lee Estingoy
Castle's Odd Jobs Guy
Lee Estingoy's Avatar
11.15.2008, 12:22 PM
If you have a V2 Monster I'd really suggest that you DON'T lengthen the wires on the switch. This may cause some serious damage to the BEC chip.
Have you just checked to see if indeed there is a short between the barrel and the heatsink? Very easy to do with a voltmeter, a battery, basic stuff that you should have laying around. Much easier to check than to speculate on a forum like this....
Lee
George16
Supermaxx
George16's Avatar
11.15.2008, 06:27 PM
Lee
Lee,
I have a V3. I lengthened the switch wire so I can install the switch inside my rx box. Since you mentioned V2, is it okay to lengthen the switch wire on the V3?
And for the second time, I'm not worried about a short . I'm going to say again that my concern is the fact that when the male connector is inserted into the ESC connector, it is pushing the connector away from the heat sink which puts undue load to the soldered point. Do you understand that? As you can see, there is no gap between the positive connector and heat sink while the negative connecto has about 2mm. I also checked the 2nd V3 I received and it was soldered better. There is at least a 2mm gap between the positive/negative terminals and heat sink.
By the way, I'm not speculating anything. If you can't help any, then I think it would be better if you just do your work at Castle to make the MMM better .
You can read this thread so you can give your input too:
http://www.rc-monster.com/forum/showthread.php?t=16497
Revo with OS .18TZ
Pdelcast
Pdelcast's Avatar
11.16.2008, 01:56 AM
Lee,
It's pretty funny (funny ironic, not funny ha-ha) that when we released the Mamba Max we were the target of unending flames (on forums just like this one...) for soldering the wires into through-holes and NOT using the same kind of "solder posts" like everybody else. Everyone claimed that the wire solder joints would fail (because of stress where the solder met the strands of the wire) and replacement wires would be a real problem... etc ... etc... etc...
Now, we are being told the opposite. Because we didn't put wires in the holes, we have a poorly engineered product ... etc. etc. etc...
I mean, I could take a hint from GM racing and not put ANY wires or bullets or posts or anything in the holes, and then not warranty the controller if the end user damages it while soldering their own wires in...
I guess my point is this -- we will be flamed regardless of how we do things, because people have preferences on how they like things. They get used to a certain way of seeing things, and then all other options just don't seem "right."
Believe me, I understand, and I'm not upset about it at all. I just think you should give it a chance. We've engineered it pretty well, and we are pretty confident that the bullets work. The bullets actually allow us to build to demand (which we haven't been able to do with the Mamba Max -- because of the amount of hand-work required for soldering...) so that EVERYONE can get (and afford!) a MMM. (AND -- the difference between the gap on your monster was a minor issue in manufacturing. We have changed the fixtures for the Monster Max to center the heat sink better between the posts. BUT -- it won't cause a problem...)
Thanx for listening to me rant...
OH -- and BTW -- yes, you can lengthen the switch wire on your V3. We actually made a hardware change so that high resistance or inductance on the switch wire wouldn't hurt the BEC from V2 to V3.
Patrick del Castillo
President, Principle Engineer
CRTIM
11.15.2008, 09:54 PM
As far as removing the switch....iv'e been thinking of removing mine but not sure of any consequeces....is there any reasons why i shouldn't remove the switch ??...thanks guys for the help
11.15.2008, 07:08 PM
Tell us how you really feel George..
pasan
I <3 RC
pasan's Avatar
11.16.2008, 12:25 AM
I haven't removed mine. I've kept the power switches on both my MMM and MM. I don't want to bother with taking the lid off and unplugging the battery each time I want to take a 10 minute break from playing with my cars.
AX10 RTR - Stock :D
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
11.16.2008, 12:36 AM
Just turning the switch off doesn't cut all power. There is still a slight parasitic draw with the switch off, all the switch kills is the BEC. Leaving your batteries plugged in isn't a good idea, especially with Lipos. If you happen to forget to unplug them you can kiss them good bye! Depending on your setup, usually you can reach under the body enough to unplug the battery. On my E-Revo I can unplug and plug the battery in with the body on, if I had to I can swap a battery with the body on. My mini late-model that I race on carpet has been getting battery swaps with the body on too.
