Originally Posted by lincpimp
That is the one I put new wires one, right? Kinda weird, Nothing looked wrong with it when I pulled it apart. Have you given the connector a good yank to make sure the soldering is good? (I use a very potent iron, but no one is perfect, right!). Do not yank on the wires as they go into the pack, not much strain relief there, Does the connector get hot when you run it? It was a traxxas connector, IIRC. May be dirty.
I just checked the connector and all is fine. The metal clips are fully seated in the TRX connector. The connector will be warm but far from hot when running it. Just barely warm.
