Quark Monsterpro 125B
Dj_Sparky
Quark Monsterpro 125B - 08.10.2010, 06:43 PM
I was looking through the instructions for this thing, but I couldn't find out exactly how to turn on lipo cutoff. I could only find how to change the voltage OF the lipo cutoff, but I just want to turn on the LVC!
Anyways, I couldn't find any programmers/ESC controller for this ESC on their site, but I found 2 other control programmers on the net, but I'm not sure if they can be used by this particular ESC since the main site doesn't list anything. Does it have a controller? Like, a USB connector and software or a field unit of some sort?
And also, I have a BEC unit for this but there's nowhere to plug it in. How does this work? :S
simplechamp
simplechamp's Avatar
08.10.2010, 08:41 PM
It can only be programmed by using your transmitter, no computer connection or program card. See the attached link for the programming manual (if you don't already have it).
You need to hook the BEC up like this: http://www.castlecreations.com/produ...ec_wiring.html
Dj_Sparky
08.10.2010, 09:03 PM
Thanks. I have another silly question, I guess. Still new to the electric game. :P
Anyways, can I program the ESC by plugging in a Lipo battery, without a motor, and not risk any damage whatsoever? Since the LVC isn't turned on. I guess I need to turn on Lipo Normal as well? Amp range will be around 150A for a monster truck app, but I don't want to risk Lipo High.
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
08.10.2010, 11:37 PM
you need to have the motor connected so you can hear the chime conformation when you are entering and exiting the different programme features...
Alien
08.10.2010, 10:46 PM
Use lipo mode, or use The Force to determine when to stop running- truck will being to loose its zippyness and ability to wheelie at any speed.
