Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
What needs replacing??
Nard Cox
n00b
What needs replacing?? - 06.26.2010, 11:30 AM
Hi guys,
I bought myself a RCM Slipperential via eBay (turned out it was from Bryan here). Now I got it but there is a big wobble in the output yokes (Bryan mentioned this in his ad). So I was just curious what I should replace:
I put together a small movie for you to check the play:
[YOUTUBE]Q54veG7vc7g[/YOUTUBE]
I'm guessing it are the two end cap plates that are worn out? I've read Mike made some hardend steel versions that should ''last forever''?
Thanks guys!
EDIT: Any other hints on what would need replacement while rebuilding, some gaskets and o-rings?
bryan
bryan's Avatar
06.26.2010, 11:45 AM
Its most likely the aluminum end caps Nard.They would wear faster than metal cups. sorry about not returning your email.
Nard Cox
n00b
06.26.2010, 11:49 AM
No problem.
I'm thinking it are the end caps as well, will order me a set together with a nice MBX6Te conversion :D
brushlessboy16
brushlessboy16's Avatar
06.26.2010, 03:20 PM
hardened steel small and large end bells
bryan
bryan's Avatar
06.27.2010, 03:00 PM
If its for bashing and weight isnt an issue,then use those.It's already pretty heavy. Use good grease in between the end caps and outdrives with either the alu. or steel end caps.
superek4
superek4's Avatar
06.27.2010, 07:27 PM
Yes the part that holds the outdrives wears out making the outdrives wobbles.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
