Go Back   RC-Monster Forums > Support Forums > Novak
Ballistic 550 (4.5T) Esc option for 3s
crusey_aus
Ballistic 550 (4.5T) Esc option for 3s - 06.01.2010, 02:10 AM
Howdy Folks,
Just wondering what you would suggest as an esc option for the following
Slash 4x4
Combination of 2s / 3s lipo
Do you have plans for a 3s capable esc that will support the 550's ?
Few folks over on the Traxxas forums seem to be having issues with the Mamba Max Pro's
I was thinking the Tekin RX8 may be an alternative
Cheers
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.01.2010, 10:00 AM
What's wrong with the MMpro and the 4.5T motor combo?
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
ta_man
06.01.2010, 07:56 PM
Originally Posted by crusey_aus View Post
Howdy Folks,
Slash 4x4
Cheers
I ran a HV6.5 on 3S with a Tekin RX8 and it worked fine.
HV4.5 on 2S is pretty fast. I would expect you to have lots of part deterioration and outright failures running the HV4.5 on 3S in a Slash 4X4, especially the center bearing.
crusey_aus
06.02.2010, 02:57 AM
Apparently issues people have been having are related to the internal bec on the MMP, adding an external bec seems to fix the problem
Guess time will tell if the RX8 has a better designed bec circuit
Cheers
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
06.02.2010, 09:44 AM
An ext BEC fixed the servo glitching for me....I believe simplechamp sent his in and is waiting to see how his updated mmp will work in his setup....
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
NovakTwo
Senior Strategist
06.25.2010, 01:17 PM
We have changed our guidance for lipo use with the Ballistic 550 4.5 from 2S/3S to 2S only. Although, it can be used with 3S under certain conditions---as long as the motor temp is carefully monitored---we decided that the potential motor damage was not worth including the 3S option.
We updated our web info and contacted our distributors to update their product listings.
"Just because you can do something doesn't mean you should." This is our project meeting motto....
Novak Electronics, Inc.
