Hitec HS-7975HB servo making noise?
Dj_Sparky
Hitec HS-7975HB servo making noise? - 07.03.2011, 07:41 PM
I just installed this servo in my SC10 and whenever I turn it, it makes a noise and basically keeps making it. It's annoying. I also tried it on a servo tester with a battery, and it made the same noise.
CarstenL
07.04.2011, 01:52 PM
Perfectly normal, all digital servos does that.
Semi Pro
Semi Pro's Avatar
07.04.2011, 03:28 PM
its mainly HS servos, my jr is pretty quiet but all of my HS servos chitter alot
Dj_Sparky
07.05.2011, 04:57 AM
Yeah, but it actually sounds like interference, but it isn't. It's like when you trim an analog servo from the remote -- sometimes it just keeps making noise. I thought Digital servos made 0 noise? I have another car with a digital servo and I don't think it makes any noise.
CarstenL
07.05.2011, 11:05 AM
I haven't had one digital servo that didn't chatter.
07.05.2011, 01:54 PM
Ditto, every servo I've owned makes some noise when it isnt at center. Even when centered, my savox 1256tg makes a little noise, usually stops if I lift the wheels of the ground and flick the steering.
Digital servos; noisey, but powerful
Swindez85
Swindez85's Avatar
07.05.2011, 02:52 PM
Same here. The HS-7955TG in my E-revo chatters (more like whines, standard servos tend to chatter) and the HS-7965MG in my evader makes the same noise.
Its just the same noise that a brushed motor makes at low speeds with an ESC. The servo control board is turning the electric motor on and off many times a second to hold the servo either at center or wherever its being demaded to hold at.
Dj_Sparky
07.06.2011, 10:12 PM
Ok, thanks guys.
Anyone made a soundproof servo box yet? :p
