Hi guys,
just want to introduce my new ride:
- Hot Bodies D8T #67800
- RC Monster Hot Bodies D8T Electric conversion kit
- Castle Creations Mamba Monster ESC
- Castle Creations Neu-Castle 1515 2200kv
- JR DS8711 Ultra Torque Servo
- Dynamite Aluminum Servo Horn #DYN2535
- Tony's Screw Hot Bodies D8T Screw Kit #TSK-D8T
- Hot Bodies Big Bore Rear Shock Spring Orange #67456
- Hot Bodies Big Bore Front Shock Spring Blue #67448
- DE Racing Hot Bodies D8T Truggy Mud Guards #DER-110-HBT
- DE Racing Hot Bodies D8T Truggy BumpSkid #DER-208-HB
- DE Racing Hot Bodies D8T Truggy XD Rear Skid Plates #DER-210-HB
- RC-Skin Big Bore Shock Cover #RCS-301
- JConcepts Rulux - 1/8th truck wheels - 1/2 offset - Half-ups #3310
- AKA 1:8 Truggy I-BEAM Tires with Foam (double taped with Gorilla Tape)
- Futaba 2PL 2.4Ghz
- EC5 connectors
7k/7k/4k diff fluid (but in the next future i'm going 7k/10k/4k)
50wt shock oil
geared 18/50 running 4s only..
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 50
Pinion Tooth Count: 18
Total Voltage: 14.80
Motor KV: 2200
Tire Diameter (inches): 5.6
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.006
Spur/Pinion Ratio: 2.78 : 1
Total Ratio: 11.94444 : 1
Tire Circumference (inches): 17.59 inches (446.86 mm)
Rollout: 1.47:1
Total Motor Speed: 32560 RPM
Vehicle Speed: 45.41 mph (72.95 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
and now a few photos.. =D ..hope you enjoy!!
